It seems Denmark has changed the way they are blocking OpenSubtitles. Instead of a direct block, they have added a redirect, which is confusing Infuse.
A fix for this will be available in the next update.
Thx, I really enjoy the subs feature, hopefully we dont have to wait too long
That’s great James, thanks a bunch!
Epic!
I found a work around until the update will hit.
I live i Denmark too.
I can acces https://www.opensubtitles.com not .org
In here i find the movie i need subtitels to, and then download it and place it in the folder of the movie i need subtitels in. Now i can get it to show in the moive.
Not the best way, better then nothing
Have a great day!
EL_HEFFE → That’s a great tip - doesn’t work for mp4’s though. Is there a workaround for that as well?
Got the same issue from Denmark and am really looking forward to a solution. In the meantime downloading from opensubtitles.com or subscene.com is a workable interrim solution.
We believe this should be resolved in today’s 6.2.4 update.
Let us know how it goes.
Subs work for me now. Thank you James.
Yes! It works, Thank you??
