All the folder art loads no problem on my ATV2 instantiation of Infuse. But it’s not working at all on the new ATV with v5.5.4 no matter what I try… and “Use local metadata” (under the long press on a folder) makes it happen for ALL the content in the folder and, ironically, not the folder image itself.
Strikes me quite strange and I can’t figure out why it might be that it works on the old version but not the new one… to be clear, I have both ATVs hitting the same core drive with all the files/art.
I think that I might have made a mistake… do you actually name the file “FOLDER.JPG”? That’s not a substitute for the actual name of the folder itself? If that’s right, and I have 2 ATVs (old and new) hitting the same data, then I’d need 2 files in each folder, one named as above and the other with the original name of the folder itself as it worked on ATV2. Is that right?
