SUB FOLDERS
HOW DO YOU CREATE SUB FOLDERS WITHIN FOLDERS IN THE LIBRARY?
FOR EXAMPLE
MAIN FOLDER- MOVIES
SUB FOLDERS- SEAL TEAM/THE BRAVE/DECEPTION
PLEASE ASSIST
Ouch. There’s no need to shout :slight_smile:
I’m not sure what you mean by “In The Library”. The sections in the Library are fixed.
But if you mean: can you create sub folders on the local device in the “Files section”? Then no. You can move files into folders and out of folders, but you can’t create sub folders.
I didn’t mean to shout. Thanks for your reply.
I think fire core should consider subfolders in the file section for better organization.
