General
Unique ID : 228070029004976210837470920853637160108 (0xAB94B0988DEB02CF38D5BF270F91DCAC)
Complete name : /Volumes/Multimedia/Video/Movies/Akira (1988)/Akira.(1988).(UHD.Blu-ray.2160p.HDR10.HEVC.TrueHD).mkv
Format : Matroska
Format version : Version 4
File size : 18.0 GiB
Duration : 2 h 4 min
Overall bit rate mode : Variable
Overall bit rate : 20.6 Mb/s
Movie name : Akira.1988.2160p.UHD.BluRay.x265-JRP
Encoded date : UTC 2020-05-25 18:44:23
Writing application : mkvmerge v46.0.0 (‘No Deeper Escape’) 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Attachments : OpenSans-Semibold.ttf / open-sans-semibold-italic.ttf / redlinesemital.ttf
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 9 260 kb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.048
Stream size : 8.07 GiB (45%)
Writing library : x265 3.3+34-ee92f3678280:[Linux][GCC 7.5.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,50) / cll=1000,369 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Language : Japanese
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 369 cd/m2
Audio #1
Format : MLP FBA
Format/Info : Meridian Lossless Packing FBA
Commercial name : Dolby TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 9 517 kb/s
Maximum bit rate : 13.9 Mb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 192 kHz
Frame rate : 1 200.000 FPS (160 SPF)
Compression mode : Lossless
Stream size : 8.29 GiB (46%)
Title : TrueHD 5.1 192kHz
Language : Japanese
Default : Yes
Forced : No
Audio #2
Format : MLP FBA
Codec ID : A_TRUEHD
Bit rate : 1 669 kb/s
Maximum bit rate : 2 835 kb/s
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Stream size : 1.45 GiB (8%)
Title : TrueHD 5.1 48kHz
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 59 min
Bit rate : 45 b/s
Count of elements : 1253
Stream size : 39.9 KiB (0%)
Title : English UHD SRT
Language : English
Default : Yes
Forced : No
Text #2
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Bit rate : 71 b/s
Stream size : 62.6 KiB (0%)
Title : English UHD SSA
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 29.0 kb/s
Count of elements : 2521
Stream size : 24.7 MiB (0%)
Title : English HDMV PGS
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Duration : 1 h 58 min
Bit rate : 25.7 kb/s
Count of elements : 2788
Stream size : 21.9 MiB (0%)
Title : Japanese HDMV PGS
Language : Japanese
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:03:04.309 : en:Chapter 02
00:05:25.283 : en:Chapter 03
00:06:58.668 : en:Chapter 04
00:10:33.507 : en:Chapter 05
00:12:11.731 : en:Chapter 06
00:16:53.887 : en:Chapter 07
00:20:37.444 : en:Chapter 08
00:23:45.340 : en:Chapter 09
00:26:44.686 : en:Chapter 10
00:29:10.081 : en:Chapter 11
00:32:10.511 : en:Chapter 12
00:35:21.577 : en:Chapter 13
00:38:14.250 : en:Chapter 14
00:41:23.147 : en:Chapter 15
00:45:05.703 : en:Chapter 16
00:47:40.107 : en:Chapter 17
00:53:16.484 : en:Chapter 18
00:57:16.850 : en:Chapter 19
01:02:32.206 : en:Chapter 20
01:05:30.176 : en:Chapter 21
01:08:36.403 : en:Chapter 22
01:11:11.058 : en:Chapter 23
01:14:30.466 : en:Chapter 24
01:18:12.270 : en:Chapter 25
01:21:31.428 : en:Chapter 26
01:25:57.485 : en:Chapter 27
01:30:47.358 : en:Chapter 28
01:36:05.509 : en:Chapter 29
01:39:38.764 : en:Chapter 30
01:41:54.900 : en:Chapter 31
01:45:42.336 : en:Chapter 32
01:49:21.680 : en:Chapter 33
01:52:23.695 : en:Chapter 34
01:56:06.960 : en:Chapter 35
01:58:24.972 : en:Chapter 36
02:00:21.297 : en:Chapter 37
02:04:33.466 : en:Chapter 38
