Stuttering HEVC/DV on Vision Pro
I noticed certain HEVC, DV (Profile 5, dvhe.05.06) files to be played with heavy stuttering only via PLEX on the Infuse Vision Pro app (currently latest version 8.0.9, VisionOS 2.2). The same files play fine with Infuse on Apple TV and other devices, and also on other Plex/player apps on the Vision Pro.
Not sure if this is a known issue, and which aspect of these files cause the stuttering. Maybe you can have a look? Any help would be much appreciated!
Format                                   : Matroska
Format-Version                           : Version 4
Dateigröße                               : 58,0 MiB
Dauer                                    : 29s 708 ms
Gesamte Bitrate                          : 16,4 Mb/s
Bildwiederholungsrate                    : 1 652,686 FPS
Kodierendes Programm                     : Lavf61.1.100
verwendete Encoder-Bibliothek            : Lavf61.1.100
ErrorDetectionType                       : Per level 1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format-Profil                            : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, Profile 5, dvhe.05.06, BL+RPU, no metadata compression
Codec-ID                                 : V_MPEGH/ISO/HEVC
Dauer                                    : 29s 541 ms
Bitrate                                  : 15,8 Mb/s
Breite                                   : 3 840 Pixel
Höhe                                     : 2 160 Pixel
Bildseitenverhältnis                     : 16:9
Ursprüngliches Bildseitenverhältnis      : 16:9
Modus der Bildwiederholungsrate          : variabel
originale Bildwiederholungsrate          : 24,000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.001
Stream-Größe                             : 3,75 GiB
Default                                  : Ja
Forced                                   : Nein
Color range                              : Full
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec-ID                                 : A_EAC3
Dauer                                    : 29s 696 ms
Bitraten-Modus                           : konstant
Bitrate                                  : 768 kb/s
Kanäle                                   : 6 Kanäle
Channel layout                           : L R C LFE Ls Rs
Samplingrate                             : 48,0 kHz
Bildwiederholungsrate                    : 31,250 FPS (1536 SPF)
Bit depth                                : 32 bits
Compression mode                         : Lossy
Video Verzögerung                        : -1s 0 ms
Stream-Größe                             : 186 MiB
Sprache                                  : Englisch
Service kind                             : Complete Main
Default                                  : Ja
Forced                                   : Nein
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1 Kanal
Bed channel configuration                : LFE
Dialog Normalization                     : -27 dB
compr                                    : -0.28 dB
dmixmod                                  : Lo/Ro
ltrtcmixlev                              : -3.0 dB
ltrtsurmixlev                            : -4.5 dB
lorocmixlev                              : -3.0 dB
lorosurmixlev                            : -4.5 dB
dialnorm_Average                         : -27 dB
dialnorm_Minimum                         : -27 dB
dialnorm_Maximum                         : -27 dB
Unfortunately the issue remains in Infuse 8.1 and VisionOS 2.3. And I noticed it also affects HDR videos with the other characteristics being the same as the example above.
…and I have accidentally found a workaround: If I start the video, then close infuse and shortly play any video with any other app (or even just open for example the Apple TV app and just browse around for a second), and then open Infuse again (which immediately returns to the problematic video that I quit) and resume the video, it suddenly plays totally fine and butter-smooth. Only if I completely stop and close the playback, and then start it again, the stuttering comes back (until I do the workaround again).
Again, only happens to videos close to the format posted above. And obviously Infuse can play it back totally fine. Just something causes it to stutter until I do this ‘trick’. Any idea why?
I agree, I have the same problem. Watching this format from a PC is impossible, endless stuttering, it was never like this before. It used to be just random flickering on PC when watching DV | 74JB8
If possible, would you be able to send in one of these problematic videos we could test here? Files of any size can be uploaded.
James, yeah, i uploaded. Thank you.
By the way, I noticed that Ipad also has stuttering sometimes, random ones not as bad as PC YK77V
Thanks for looking into this! I have uploaded a sample as well of such a problematic video for the vision pro issue described in the original post. Note that this one plays fine for me on other devices including PC and iPad, and even on the vision pro if I apply the workaround described in the second post.
Also worth mentioning that this issue remains with Infuse 8.1.2 and Vision OS 2.3.2 as well as 2.4 (beta 3).
Sorry, I also found one more bug with the same video profile, if the video is played picture in picture on ipad there are continuous stutters like when playing on macbook.
I have noticed this happens to me as well. It’s been going on for many months. I notice it the most for a panning shot in a movie. It looks like the FPS go down to 12-18 FPS. I can hardly tell for regular shots with minimal camera movement.
It does not happen for all media. I’d say maybe 40% of the things I play.
There are a number of playback related improvements for visionOS (and other platforms) included in the recently released 8.3 update. Please give this version a try and let us know if you see any further issues. Thanks!
Thanks James! I can confirm that the issues with the DV videos mentioned in the OP are gone. Good job! :smiley:
EDIT: disregard. did not see this was a thread for vision pro.
Hi James! thanks for following up on this. I’m encountering a similar problem with Dolby vision content. I’m on infuse 8.3 but I’m still seeing it nevertheless. here’s the media info:
General
Unique ID                                : 219099871826404597959089245022775474349 (0xA4D519B3908734AE02C1A464B73CF8AD)
Complete name                            : Barry.Lyndon.1975.UHD.BluRay.1080p.DDP.5.1.DoVi.HDR10.x265-SM737/Barry.Lyndon.1975.UHD.BluRay.1080p.DDP.5.1.DoVi.HDR10.x265-SM737.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 10.5 GiB
Duration                                 : 3 h 5 min
Overall bit rate                         : 8 133 kb/s
Frame rate                               : 23.976 FPS
Encoded date                             : 2025-06-29 07:26:01 UTC
Writing application                      : mkvmerge v91.0 ('Signs') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1 / Lavf61.7.100
Video
Format                                   : HEVC
Format profile                           : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.10, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 6 942 kb/s
Width                                    : 1 792 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 5:3
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.150
Stream size                              : 8.98 GiB (85%)
Writing library                          : x265 4.1+1-1d117be:[Windows][GCC 13.2.0][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1792x1080 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / hrd / info / hash=0 / temporal-layers=0 / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=16 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6900 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=4 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass / no-mcstf / no-sbrc / no-frame-rc
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
