I have been trying to jailbreak my ATV2 for a while now, everything seems to go great I get no errors in iTunes but when I plug the HDMI/Power in all I get is the USB and Itunes logo on my TV.
I have tried every combination of:
Power + USB with seas0npass
USB Only with seas0npass
iReb5 to lock into DFU mode
Deleting any apple entries in /etc/hosts
seas0npass log:
DateTime: 04/04/2012 11:19:00 Message: Application start
DateTime: 04/04/2012 11:19:00 Message: Seas0nPass 0.8.3.5592
DateTime: 04/04/2012 11:19:00 Message: clean up
DateTime: 04/04/2012 11:19:07 Message: Started iTunes exe search
DateTime: 04/04/2012 11:19:08 Message: Using registry view Default
DateTime: 04/04/2012 11:19:08 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 04/04/2012 11:19:08 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 04/04/2012 11:19:08 Message: Found 113 subKeyNames
DateTime: 04/04/2012 11:19:08 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{23B8A91D-680B-462B-87AD-3D70F7341731}
DateTime: 04/04/2012 11:19:08 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 04/04/2012 11:19:29 Message: Original firmware found on disk
DateTime: 04/04/2012 11:19:39 Message: Patching message changed to: Unzipping…
DateTime: 04/04/2012 11:20:19 Message: Patching message changed to: Decrypting ramdisk…
DateTime: 04/04/2012 11:20:20 Message: Running process: .\bin\xpwntool.exe, args: .\UNZIPPED_ORIGINAL\038-4309-008.dmg ipsw/038-4309-008.dmg -iv 89aa32f2a98f6e9b55640e77f7dbd705 -k 1de9d6e54b29e0c7968cb8659bfaf1424a5a02dd22695ecc6ae9d33942985d72
DateTime: 04/04/2012 11:20:25 Message: Patching message changed to: Patching ramdisk…
DateTime: 04/04/2012 11:20:25 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg extract /usr/sbin/asr .\tmp\asr
DateTime: 04/04/2012 11:20:26 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg mv /usr/sbin/asr /usr/sbin/asr_backup
DateTime: 04/04/2012 11:20:27 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg grow 25690112
DateTime: 04/04/2012 11:20:27 Message: Running process: .\bin\bspatch.exe, args: .\tmp\asr .\tmp\asr.patched .\patches\9B179b\asr.patch
DateTime: 04/04/2012 11:20:28 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg add .\tmp\asr.patched /usr/sbin/asr
DateTime: 04/04/2012 11:20:28 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg chmod 755 /usr/sbin/asr
DateTime: 04/04/2012 11:20:28 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/BasebandAudioParameters.c
DateTime: 04/04/2012 11:20:28 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our.dmg rm /usr/local/standalone/firmware/ICE2.Release.bbfw
DateTime: 04/04/2012 11:20:28 Message: Patching message changed to: Encrypting ramdisk…
DateTime: 04/04/2012 11:20:28 Message: Running process: .\bin\xpwntool.exe, args: .\tmp\our.dmg .\output\038-4309-008.dmg -iv 89aa32f2a98f6e9b55640e77f7dbd705 -k 1de9d6e54b29e0c7968cb8659bfaf1424a5a02dd22695ecc6ae9d33942985d72 -t .\UNZIPPED_ORIGINAL\038-4309-008.dmg
DateTime: 04/04/2012 11:20:29 Message: Patching message changed to: Decrypting file system…
DateTime: 04/04/2012 11:20:29 Message: Running process: .\bin\vfdecrypt.exe, args: -i .\UNZIPPED_ORIGINAL\038-1777-212.dmg -k 6789bda31f66e753da9e87e9424659430846049109726cced20319f1a9c43621c5b402b4 -o ipsw/038-1777-212.dmg
DateTime: 04/04/2012 11:21:07 Message: Running process: .\bin\dmg-bin.exe, args: extract .\tmp\our-big.dmg .\tmp\our-big-hfsimage.dmg
DateTime: 04/04/2012 11:21:50 Message: Patching message changed to: Patching file system…
DateTime: 04/04/2012 11:21:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg grow 696721408
DateTime: 04/04/2012 11:21:53 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg extract /etc/fstab .\tmp\fstab
DateTime: 04/04/2012 11:21:53 Message: Running process: .\bin\bspatch.exe, args: .\tmp\fstab .\tmp\fstab.patched .\patches\9B179b\fstab.patch
DateTime: 04/04/2012 11:21:54 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /etc/fstab /etc/fstab_backup
DateTime: 04/04/2012 11:21:54 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\tmp\fstab.patched /etc/fstab
DateTime: 04/04/2012 11:21:54 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /etc/fstab
DateTime: 04/04/2012 11:21:55 Message: Patching message changed to: Installing software…
DateTime: 04/04/2012 11:21:58 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/sbin/rtadvd /usr/sbin/rtadvd_backup
DateTime: 04/04/2012 11:21:58 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg untar .\tmp\cydia\cydia.tar
DateTime: 04/04/2012 11:23:44 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\asubstratesafe.deb /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 04/04/2012 11:23:44 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/asubstratesafe.deb
DateTime: 04/04/2012 11:23:45 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\bsubstrate.deb /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 04/04/2012 11:23:45 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/bsubstrate.deb
DateTime: 04/04/2012 11:23:45 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\awkwardtv.deb /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 04/04/2012 11:23:45 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/awkwardtv.deb
DateTime: 04/04/2012 11:23:45 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.nito.deb /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 04/04/2012 11:23:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.nito.deb
DateTime: 04/04/2012 11:23:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\org.xbmc.repo_0.1-1_iphoneos-arm.deb /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 04/04/2012 11:23:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/org.xbmc.repo_0.1-1_iphoneos-arm.deb
DateTime: 04/04/2012 11:23:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\syslogd.deb /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 04/04/2012 11:23:46 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/syslogd.deb
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\DEBS\com.firecore.seas0npass.deb /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 644 /private/var/root/Media/Cydia/AutoInstall/com.firecore.seas0npass.deb
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /var/stash
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mkdir /usr/include
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Applications /var/stash/Applications
DateTime: 04/04/2012 11:23:47 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Ringtones /var/stash/Ringtones
DateTime: 04/04/2012 11:23:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /Library/Wallpaper /var/stash/Wallpaper
DateTime: 04/04/2012 11:23:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/bin /var/stash/bin
DateTime: 04/04/2012 11:23:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/include /var/stash/include
DateTime: 04/04/2012 11:23:48 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/lib/pam /var/stash/pam
DateTime: 04/04/2012 11:23:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/libexec /var/stash/libexec
DateTime: 04/04/2012 11:23:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg mv /usr/share /var/stash/share
DateTime: 04/04/2012 11:23:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Applications var/stash/Applications
DateTime: 04/04/2012 11:23:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Ringtones …/var/stash/Ringtones
DateTime: 04/04/2012 11:23:49 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /Library/Wallpaper …/var/stash/Wallpaper
DateTime: 04/04/2012 11:23:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/bin …/var/stash/bin
DateTime: 04/04/2012 11:23:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/include …/var/stash/include
DateTime: 04/04/2012 11:23:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/lib/pam …/…/var/stash/pam
DateTime: 04/04/2012 11:23:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/libexec …/var/stash/libexec
DateTime: 04/04/2012 11:23:50 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg symlink /usr/share …/var/stash/share
DateTime: 04/04/2012 11:23:51 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Applications
DateTime: 04/04/2012 11:23:51 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Ringtones
DateTime: 04/04/2012 11:23:51 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /Library/Wallpaper
DateTime: 04/04/2012 11:23:51 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/bin
DateTime: 04/04/2012 11:23:51 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/include
DateTime: 04/04/2012 11:23:52 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/lib/pam
DateTime: 04/04/2012 11:23:52 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/libexec
DateTime: 04/04/2012 11:23:52 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmodh 755 /usr/share
DateTime: 04/04/2012 11:23:52 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg add .\patches\9B179b\uncompress /bin/uncompress
DateTime: 04/04/2012 11:23:52 Message: Running process: .\bin\hfsplus.exe, args: .\tmp\our-big-hfsimage.dmg chmod 755 /bin/uncompress
DateTime: 04/04/2012 11:23:53 Message: Patching message changed to: Creating IPSW…
DateTime: 04/04/2012 11:23:53 Message: Running process: .\bin\dmg-bin.exe, args: build .\tmp\our-big-hfsimage.dmg .\output\038-1777-212.dmg
DateTime: 04/04/2012 11:25:03 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead
DateTime: 04/04/2012 11:25:04 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBSS.dfu .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\patches\9B179b\iBSS.k66ap.RELEASE.patch
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBSS.dfu .\OUTPUT\Firmware\dfu\encrypted_iBSS.dfu -iv 67b821977559b8035887d46d68eb5b7b -k 2f442e98254dde0a75ca8d35ea48644bce9efdeb34332e0ec730e848539acead -t .\OUTPUT\Firmware\dfu\iBSS.k66ap.RELEASE.dfu
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\Firmware\dfu\decrypted_iBEC.dfu .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\patches\9B179b\iBEC.k66ap.RELEASE.patch
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\Firmware\dfu\patched_iBEC.dfu .\OUTPUT\Firmware\dfu\encrypted_iBEC.dfu -iv d12f8e04287683c4e2b67feb5fa6e308 -k 975cf31cc14d83389e8136f68f0c26303d7d1db4b197c5f0a3c12b152cde626f -t .\OUTPUT\Firmware\dfu\iBEC.k66ap.RELEASE.dfu
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\kernelcache.release.k66 .\OUTPUT\decrypted.kernelcache -iv 7f3aebd9ca605b2301ca44c342978c75 -k 4bf06a4279189e2222daef359178ef7cd7e5ee3c1c6fcdb350a8e722d22dd88d
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\bspatch.exe, args: .\OUTPUT\decrypted.kernelcache .\OUTPUT\patched.kernelcache .\patches\9B179b\kernelcache.release.patch
DateTime: 04/04/2012 11:25:06 Message: Running process: .\bin\xpwntool.exe, args: .\OUTPUT\patched.kernelcache .\OUTPUT\encrypted.kernelcache -iv 7f3aebd9ca605b2301ca44c342978c75 -k 4bf06a4279189e2222daef359178ef7cd7e5ee3c1c6fcdb350a8e722d22dd88d -t .\OUTPUT\kernelcache.release.k66
DateTime: 04/04/2012 11:25:08 Message: Patching message changed to: Compressing IPSW…
DateTime: 04/04/2012 11:26:15 Message: Saving kernelcache.release.k66 and iBSS.k66ap.RELEASE.dfu files
DateTime: 04/04/2012 11:26:15 Message: Directory C:\Users\Josh\AppData\Roaming\Seas0nPass\AppleTV2,1_5.0_9B179b recreated successfully
DateTime: 04/04/2012 11:26:15 Message: kernelcache.release.k66 file copied successfully
DateTime: 04/04/2012 11:26:15 Message: iBSS.k66ap.RELEASE.dfu file copied successfully
DateTime: 04/04/2012 11:26:15 Message: iBEC.k66ap.RELEASE.dfu file copied successfully
DateTime: 04/04/2012 11:26:16 Message: Restoring DFU file
DateTime: 04/04/2012 11:26:16 Message: DFU process starting for iBSS.k66ap.RELEASE.dfu iBEC.k66ap.RELEASE.dfu
DateTime: 04/04/2012 11:26:20 Message: Output received: ERROR: The process “iTunes.exe” not found.
DateTime: 04/04/2012 11:26:21 Message: Output received: ERROR: The process “iTunesHelper.exe” not found.
DateTime: 04/04/2012 11:26:21 Message: Output received: ::Waiting for device to enter DFU mode…
DateTime: 04/04/2012 11:26:28 Message: Output received: Initializing libpois0n
DateTime: 04/04/2012 11:26:28 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:26:28 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:26:28 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:28 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:28 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:26:28 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:26:28 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:26:28 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:26:36 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:36 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:26:36 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:26:36 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:26:36 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:26:36 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:26:36 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:26:36 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:43 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:43 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:43 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:26:43 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:26:43 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:26:43 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:26:43 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:26:43 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:26:51 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:26:51 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:26:51 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:26:51 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:26:51 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:26:51 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:26:51 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:51 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:59 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:59 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:26:59 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:26:59 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:26:59 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:26:59 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:26:59 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:26:59 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:06 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:06 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:06 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:06 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:06 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:06 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:06 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:06 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:14 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:14 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:14 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:14 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:14 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:14 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:14 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:14 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:21 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:21 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:21 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:21 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:21 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:21 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:21 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:21 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:29 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:29 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:29 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:29 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:29 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:29 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:29 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:29 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:37 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:37 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:37 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:37 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:37 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:37 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:37 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:37 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:44 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:44 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:44 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:44 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:44 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:44 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:44 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:44 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:52 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:52 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:52 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:52 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:52 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:52 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:52 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:27:52 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:59 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:59 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:27:59 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:27:59 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:27:59 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:27:59 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:27:59 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:27:59 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:07 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:07 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:07 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:07 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:07 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:07 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:07 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:07 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:15 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:15 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:15 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:15 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:15 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:15 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:15 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:15 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:22 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:22 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:22 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:22 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:22 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:22 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:22 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:22 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:31 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:31 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:31 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:31 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:31 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:31 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:31 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:31 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:38 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:38 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:38 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:38 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:38 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:38 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:38 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:38 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:46 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:46 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:46 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:46 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:46 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:46 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:46 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:46 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:54 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:28:54 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:28:54 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:28:54 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:28:54 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:28:54 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:28:54 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:28:54 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:01 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:01 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:01 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:01 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:01 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:01 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:01 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:01 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:09 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:09 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:09 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:09 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:09 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:09 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:09 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:09 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:17 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:17 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:17 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:17 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:17 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:17 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:17 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:17 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:24 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:24 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:24 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:24 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:24 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:24 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:24 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:24 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:32 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:32 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:32 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:32 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:32 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:32 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:32 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:32 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:39 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:39 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:39 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:39 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:39 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:39 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:39 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:39 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:47 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:47 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:47 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:47 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:47 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:47 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:47 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:47 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:55 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:29:55 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:29:55 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:29:55 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:29:55 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:29:55 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:29:55 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:29:55 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:02 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:02 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:02 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:30:02 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:30:02 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:30:02 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:30:02 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:30:02 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:30:10 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:10 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:30:10 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:30:10 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:30:10 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:30:10 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:30:10 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:30:10 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:16 Message: Output received: ::Found device in DFU mode…
DateTime: 04/04/2012 11:30:22 Message: Output received: ::Uploading iBSS.k66ap.RELEASE.dfu to the device
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 3.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: not iBoot mode (iBootPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:22 Message: Output received: not DFU mode (DfuPath = \?\usb#vid_05ac&pid_1281#cpid:8930_cprv:20_cpfm:03_scep:02_bdid:10_ecid:000003df2d0c550e_ibfl:03_srnm:[c07h1057ddr5]#{ed82a167-d61a-4af6-9ab6-11e52236c576}\ib0000)
DateTime: 04/04/2012 11:30:22 Message: Output received: RecoveryMode2 mode set
DateTime: 04/04/2012 11:30:22 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:30:22 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:30:22 Message: Output received: Device must be in DFU mode to continue
DateTime: 04/04/2012 11:30:22 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 6.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:30:22 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 04/04/2012 11:30:22 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 04/04/2012 11:30:22 Message: Output received: NO mode set
DateTime: 04/04/2012 11:30:22 Message: Output received: DFU mode set
DateTime: 04/04/2012 11:30:22 Message: Output received: Checking the device type
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(656635A1)
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context passed
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(65662E8C)
DateTime: 04/04/2012 11:30:22 Message: Output received: Preparing to upload limera1n exploit
DateTime: 04/04/2012 11:30:22 Message: Output received: Resetting device counters
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(656610C9)
DateTime: 04/04/2012 11:30:22 Message: Output received: Sending chunk headers
DateTime: 04/04/2012 11:30:22 Message: Output received: Sending exploit payload
DateTime: 04/04/2012 11:30:22 Message: Output received: Sending fake data
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(FFFFFFFF)
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(656634A4)
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_get_status+
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(65662767)
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_get_status context check ok
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_get_status control transfer ok
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 9.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(00B10A78)
DateTime: 04/04/2012 11:30:22 Message: Output received: Exploit sent
DateTime: 04/04/2012 11:30:22 Message: Output received: Reconnecting to device
DateTime: 04/04/2012 11:30:22 Message: Output received: Waiting 2 seconds for the device to pop up…
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_send_file(00B10A78, iBSS.k66ap.RELEASE.dfu, 1)
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(656625C9)
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context ok
DateTime: 04/04/2012 11:30:22 Message: Output received: file opened
DateTime: 04/04/2012 11:30:22 Message: Output received: buffer allocated
DateTime: 04/04/2012 11:30:22 Message: Output received: file content stored in memory
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_send_buffer(00B10A78,00620048,64004,1)
DateTime: 04/04/2012 11:30:22 Message: Output received: check_context(65662899)
DateTime: 04/04/2012 11:30:22 Message: Output received: context checked ok
DateTime: 04/04/2012 11:30:22 Message: Output received: transfer initiated
DateTime: 04/04/2012 11:30:22 Message: Output received: 32 packets will be sent
DateTime: 04/04/2012 11:30:22 Message: Output received: control transfer with status = 0
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 12.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 16.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 19.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 22.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 25.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 28.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 32.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 35.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 38.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 41.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 44.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 48.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 51.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 54.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 57.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 60.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 64.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 67.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 70.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 73.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 76.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 80.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 83.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 86.4%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 89.6%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 92.8%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 96.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 99.2%
DateTime: 04/04/2012 11:30:22 Message: Output received: ## 100.0%
DateTime: 04/04/2012 11:30:22 Message: Output received: irecv_send_file result = 0
DateTime: 04/04/2012 11:30:32 Message: Output received: ::Uploading iBEC.k66ap.RELEASE.dfu to the device
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 1.1%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 2.1%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 3.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 4.3%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 5.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 6.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 7.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 8.6%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 9.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 10.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 11.8%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 12.9%
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context(65662767)
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context passed
DateTime: 04/04/2012 11:30:32 Message: Output received: irecv_get_status context check ok
DateTime: 04/04/2012 11:30:32 Message: Output received: irecv_get_status control transfer ok
DateTime: 04/04/2012 11:30:32 Message: Output received: control transfer with status = 0
DateTime: 04/04/2012 11:30:32 Message: Output received: irecv_get_status+
DateTime: 04/04/2012 11:30:32 Message: Output received: usb packets sending done, finishing transfer
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context(65907060)
DateTime: 04/04/2012 11:30:32 Message: Output received: file content sent to device with status = 0
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context(656637CD)
DateTime: 04/04/2012 11:30:32 Message: Output received: Waiting 10 seconds for the device to pop up…
DateTime: 04/04/2012 11:30:32 Message: Output received: mobiledevice_connect+
DateTime: 04/04/2012 11:30:32 Message: Output received: mobiledevice_openpipes+
DateTime: 04/04/2012 11:30:32 Message: Output received: not iBoot mode (iBootPath = (null))
DateTime: 04/04/2012 11:30:32 Message: Output received: not DFU mode (DfuPath = (null))
DateTime: 04/04/2012 11:30:32 Message: Output received: DFU mode set
DateTime: 04/04/2012 11:30:32 Message: Output received: mobiledevice_openpipes-
DateTime: 04/04/2012 11:30:32 Message: Output received: mobiledevice_connect OK
DateTime: 04/04/2012 11:30:32 Message: Output received: irecv_send_file(00B10A78, iBEC.k66ap.RELEASE.dfu, 1)
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context(656625C9)
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context ok
DateTime: 04/04/2012 11:30:32 Message: Output received: file opened
DateTime: 04/04/2012 11:30:32 Message: Output received: buffer allocated
DateTime: 04/04/2012 11:30:32 Message: Output received: file content stored in memory
DateTime: 04/04/2012 11:30:32 Message: Output received: irecv_send_buffer(00B10A78,00620048,190980,1)
DateTime: 04/04/2012 11:30:32 Message: Output received: check_context(65662899)
DateTime: 04/04/2012 11:30:32 Message: Output received: context checked ok
DateTime: 04/04/2012 11:30:32 Message: Output received: transfer initiated
DateTime: 04/04/2012 11:30:32 Message: Output received: 94 packets will be sent
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 13.9%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 15.0%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 16.1%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 17.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 18.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 19.3%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 20.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 21.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 22.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 23.6%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 24.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 25.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 26.8%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 27.9%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 29.0%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 30.0%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 31.1%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 32.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 33.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 34.3%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 35.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 36.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 37.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 38.6%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 39.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 40.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 41.8%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 42.9%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 44.0%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 45.0%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 46.1%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 47.2%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 48.3%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 49.3%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 50.4%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 51.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 52.5%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 53.6%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 54.7%
DateTime: 04/04/2012 11:30:32 Message: Output received: ## 55.8%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 56.8%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 57.9%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 59.0%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 60.1%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 61.1%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 62.2%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 63.3%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 64.3%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 65.4%
DateTime: 04/04/2012 11:30:33 Message: Output received: irecv_get_status context check ok
DateTime: 04/04/2012 11:30:33 Message: Output received: irecv_get_status control transfer ok
DateTime: 04/04/2012 11:30:33 Message: Output received: control transfer with status = 0
DateTime: 04/04/2012 11:30:33 Message: Output received: irecv_get_status+
DateTime: 04/04/2012 11:30:33 Message: Output received: check_context(65662767)
DateTime: 04/04/2012 11:30:33 Message: Output received: check_context passed
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 66.5%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 67.6%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 68.6%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 69.7%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 70.8%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 71.8%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 72.9%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 74.0%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 75.1%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 76.1%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 77.2%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 78.3%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 79.4%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 80.4%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 81.5%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 82.6%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 83.6%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 84.7%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 85.8%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 86.9%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 87.9%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 89.0%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 90.1%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 91.2%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 92.2%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 93.3%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 94.4%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 95.4%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 96.5%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 97.6%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 98.7%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 99.7%
DateTime: 04/04/2012 11:30:33 Message: Output received: ## 100.0%
DateTime: 04/04/2012 11:30:33 Message: Output received: irecv_send_file result = 0
DateTime: 04/04/2012 11:30:33 Message: Output received: Checking if device is compatible with this jailbreak
DateTime: 04/04/2012 11:30:33 Message: Output received: Identified device as AppleTV2,1
DateTime: 04/04/2012 11:30:33 Message: Output received: usb packets sending done, finishing transfer
DateTime: 04/04/2012 11:30:33 Message: Output received: check_context(65907060)
DateTime: 04/04/2012 11:30:33 Message: Output received: file content sent to device with status = 0
DateTime: 04/04/2012 11:30:33 Message: Output received: Exiting libpois0n
DateTime: 04/04/2012 11:30:33 Message: Started iTunes exe search
DateTime: 04/04/2012 11:30:33 Message: Using registry view Default
DateTime: 04/04/2012 11:30:33 Message: Opened HKEY_LOCAL_MACHINE registry key
DateTime: 04/04/2012 11:30:33 Message: Opened HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall registry key
DateTime: 04/04/2012 11:30:33 Message: Found 113 subKeyNames
DateTime: 04/04/2012 11:30:33 Message: Found iTunes in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{23B8A91D-680B-462B-87AD-3D70F7341731}
DateTime: 04/04/2012 11:30:33 Message: Path to iTunes is C:\Program Files\iTunes\iTunes.exe
DateTime: 04/04/2012 11:30:33 Message: Starting iTunes at path C:\Program Files\iTunes\iTunes.exe
DateTime: 04/04/2012 11:30:39 Message: Control named “MainForm” found! Handle: (null)
DateTime: 04/04/2012 11:30:40 Message: Control named “MainForm” found! Handle: (null)
DateTime: 04/04/2012 11:30:41 Message: Control named “MainForm” found! Handle: (null)
DateTime: 04/04/2012 11:30:45 Message: Control named “MainForm” found! Handle: Handle: 3C0284
DateTime: 04/04/2012 11:30:46 Message: Control named “aTV panel” found! Handle: Handle: 1404D4
DateTime: 04/04/2012 11:30:46 Message: Closing Modal Dialogs
DateTime: 04/04/2012 11:30:46 Message: Control named “Found modal dialog” found! Handle: (null)
DateTime: 04/04/2012 11:30:46 Message: Set iTunes to foreground
DateTime: 04/04/2012 11:30:46 Message: Apple TV panel found! Handle: 1404D4
DateTime: 04/04/2012 11:30:46 Message: Control named “Firmware restore button” found! Handle: Handle: D0634
DateTime: 04/04/2012 11:30:46 Message: Restore button found! Handle: D0634
DateTime: 04/04/2012 11:30:46 Message: Pressing Shift
DateTime: 04/04/2012 11:30:47 Message: Before Restore Click
DateTime: 04/04/2012 11:30:47 Message: Releasing Shift
DateTime: 04/04/2012 11:30:47 Message: Open File Dialog processing
DateTime: 04/04/2012 11:30:48 Message: Control named “Open File Dialog” found! Handle: (null)
DateTime: 04/04/2012 11:30:48 Message: Looking for another dialog
DateTime: 04/04/2012 11:30:48 Message: Control named “Open File Dialog” found! Handle: Handle: 380656
DateTime: 04/04/2012 11:30:49 Message: Control named “Path TextBox” found! Handle: Handle: 180480
DateTime: 04/04/2012 11:30:49 Message: Path text box found
DateTime: 04/04/2012 11:30:49 Message: Path value set
DateTime: 04/04/2012 11:30:49 Message: Set dialog as ForegroundWindow and send enter to it
DateTime: 04/04/2012 11:30:49 Message: Work with confirmation dialog
DateTime: 04/04/2012 11:30:50 Message: Control named “Confirmation dialog” found! Handle: Handle: 2D044C
DateTime: 04/04/2012 11:30:50 Message: clean up
DateTime: 04/04/2012 11:30:50 Message: After Restore Click
Exception occured
Application: Seas0nPass
Version: 0.8.3.5592
Date: 04/04/2012 11:30:51
Computer name: MERCUTIO
User name: Josh
OS: Microsoft Windows NT 6.1.7600.0
Culture: en-US
Resolution: {Width=1680, Height=1050}
App up time: 00:11:55.3759172
Exception classes:
System.IO.IOException
Exception messages:
The process cannot access the file ‘C:\Users\Josh\AppData\Local\Temp\Seas0nPass\BIN’ because it is being used by another process.
Stack Traces:
at System.IO.Directory.DeleteHelper(String fullPath, String userPath, Boolean recursive)
at System.IO.Directory.Delete(String fullPath, String userPath, Boolean recursive)
at Seas0nPass.Utils.SafeDirectory.<>c__DisplayClass7.<Delete>b__6()
at Seas0nPass.Utils.BaseIOUtils.RepeatActionWithDelay(Action action)
at Seas0nPass.Utils.SafeDirectory.Delete(String name, Boolean recursive)
at Seas0nPass.Utils.MiscUtils.CleanUp()
Loaded Modules:
D:\g01di3l0ck5\Seas0nPass.exe 0.8.3.5592
C:\Windows\SYSTEM32\ntdll.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\SYSTEM32\MSCOREE.DLL 4.0.31106.0 (Main.031106-0000)
C:\Windows\system32\KERNEL32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\KERNELBASE.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\ADVAPI32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\msvcrt.dll 7.0.7600.16385 (win7_rtm.090713-1255)
C:\Windows\SYSTEM32\sechost.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\RPCRT4.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\system32\SHLWAPI.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\GDI32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\USER32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\LPK.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\USP10.dll 1.0626.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\IMM32.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\MSCTF.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Program Files\Common Files\Logishrd\LVMVFM\LVPrcInj.dll 11.1.0.2021
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\system32\MSVCR100_CLR0400.dll 10.00.30319.1
C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\246f1a5abb686b9dcdf22d3505b08cea\mscorlib.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\system32\ole32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\CRYPTBASE.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\uxtheme.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System\964da027ebca3b263a05cadb8eaa20a3\System.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\dd57bc19f5807c6dbe8f88d4a23277f6\System.Drawing.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\17e020ae92d7fab33bcc1c98b25019d0\System.Windows.Forms.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\shfolder.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\SHELL32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\ac18c2dcd06bd2a0589bac94ccae5716\System.Configuration.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\e997d0200c25f7db6bd32313d50b729d\System.Xml.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\version.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7600.16385_none_ebf82fc36c758ad5\comctl32.dll 6.10 (win7_rtm.090713-1255)
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_none_421189da2b7fabfc\comctl32.dll 6.10 (win7_rtm.090713-1255)
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\713647b987b140a17e3c4ffe4c721f85\System.Core.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\CRYPTSP.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\rsaenh.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\WindowsCodecs.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Seri#\e9f8a45b1063d6c6a62718c88a5623d1\System.Runtime.Serialization.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\assembly\NativeImages_v4.0.30319_32\SMDiagnostics\4d2a51c03b27e615ff9f1c430f2014ba\SMDiagnostics.ni.dll 4.0.30319.1 (RTMRel.030319-0100)
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Runtime.Dura#\f3989d3e9cb8904e4edf23ede5adb6c1\System.Runtime.DurableInstancing.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\OLEAUT32.dll 6.1.7600.16385
C:\Windows\system32\RpcRtRemote.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\apphelp.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\assembly\NativeImages_v4.0.30319_32\UIAutomationClient\ece129234f9ba9ad856d0e77e4849137\UIAutomationClient.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\UIAutomationCore.dll 7.0.0.0 (win7_rtm.090713-1255)
C:\Windows\system32\PSAPI.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\OLEACC.dll 7.0.0.0 (win7_rtm.090713-1255)
C:\Windows\assembly\NativeImages_v4.0.30319_32\UIAutomationProvider\0eb3c18ec758534395684f3ca286a201\UIAutomationProvider.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\UIAutomationTypes\5786f917a7b62d63ca8dd5b47aaf9610\UIAutomationTypes.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\UIAutomationClients#\5904383f7c86f1374a14198872dfa7d8\UIAutomationClientsideProviders.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\Accessibility\01254caa0efc15b5cd48fb3178018701\Accessibility.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\WindowsBase\d17606e813f01376bd0def23726ecc62\WindowsBase.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml.Linq\8eca92a64c232f34b5b559625b022369\System.Xml.Linq.ni.dll 4.0.30319.1 built by: RTMRel
C:\Windows\system32\rasapi32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\rasman.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\WS2_32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\NSI.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\rtutils.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\mswsock.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\System32\wshtcpip.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\System32\wship6.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\winhttp.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\webio.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\peerdist.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\USERENV.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\profapi.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\AUTHZ.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\SspiCli.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\credssp.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\IPHLPAPI.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\WINNSI.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\dhcpcsvc6.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\dhcpcsvc.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\CFGMGR32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\DNSAPI.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Program Files\Bonjour\mdnsNSP.dll 3,0,0,10
C:\Windows\system32\rasadhlp.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\System32\fwpuclnt.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\dwmapi.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\CLBCatQ.DLL 2001.12.8530.16385 (win7_rtm.090713-1255)
C:\Windows\system32\bcrypt.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\PROPSYS.dll 7.00.7600.16385 (win7_rtm.090713-1255)
C:\Windows\System32\ieframe.dll 8.00.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\iertutil.dll 8.00.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\urlmon.dll 8.00.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\CRYPT32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\MSASN1.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\SETUPAPI.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\DEVOBJ.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\ntmarta.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\WLDAP32.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\System32\shdocvw.dll 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Windows\system32\SXS.DLL 6.1.7600.16385 (win7_rtm.090713-1255)
C:\Program Files\Internet Explorer\ieproxy.dll 8.00.7600.16385 (win7_rtm.090713-1255)
C:\Windows\Microsoft.NET\Framework\v2.0.50727\System.EnterpriseServices.Thunk.dll 2.0.50727.4927 (NetFXspW7.050727-4900)
C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll 10.0.30319.1 built by: RTMRel
Exception occured
Version: 0.8.3.5592
Date: 04/04/2012 11:30:54
User name: Josh
Culture: en-US
App up time: 00:11:58.2990844
Exception classes:
Exception messages:
Stack Traces:
at Seas0nPass.Utils.MiscUtils.RecreateDirectory(String dirPath)
Loaded Modules:
DateTime: 04/04/2012 11:35:06 Message: Application Exit
DateTime: 04/04/2012 11:35:06 Message: clean up
Exception occured
Version: 0.8.3.5592
Date: 04/04/2012 11:35:07
User name: Josh
Culture: en-US
App up time: 00:16:10.7365230
Exception classes:
Exception messages:
Stack Traces:
Loaded Modules:
