Streaming from Time Capsule with little breaks every 3 sec
I have successfully mounted my TC and I can see and play files from there.
I only have a little problem:
While playing/streaming a file, there are little interrupts/breaks in the film every 3-4 seconds (duration only a split second). If I put the file on my ATV and play it directly from the ATV there are no breaks and the film is fine.
Anyone an idea?
Thanks and greetings from Germany
Max
P.S. I have ATV Version 1.0 updated on 2.2
You can adjust the file cache time in the DVD > Settings menu. This should help your streaming playback.
