Streaming from pCloud
I’m looking forward to streaming my content from pCloud however is it reliable? How long is it to load and also, does it work if my Pcloud is encrypted?
Thanks for your help.
Erwann
Encrypted content in pCloud won’t be available, but all connections from Infuse to pCloud will be fully secure.
Streaming performance for cloud services can vary a bit depending on your location, but you can test the speeds you are able to get in Infuse by adding a connection to pCloud and running a speed test.
Hi James, thank you for your quick reply.
So just to be clear, if I purchase the extra encryption option from pCloud when purchasing my storage, I will not be able to stream it via infuse?
In pCloud you can have things stored in ‘Files’ and things stored in the ‘Crypto’ folder.
Infuse will be able to access the items you have in Files but not in Crypto. This is related to current limitations in their APIs.
