Hello everyone, hope you can help me.
I looked through the site, but didn’t find what I needed.
I have an iMac intel Mac OS X 10.7 and appleTV 1st Gen
Is it possible to stream video like this:
video MPEG-TSresolution 1280*720 fps: 59.940 bitrate 6000kps scan Progressive
audio AC-3 | 384 Kbps | 2 channels | size ~4.5 GB
If I can’t, then can the 2nd generation AppleTV play it?
Thank you for your help.
james
2
Unfortunately that particular file was recorded at 60 FPS, which is quite high and won’t be supported on the AppleTV.
Most normal content is recorded at 24-30 FPS.
Thank you James,
So even the new Apple TV won’t play it?
james
4
Sorry, 60 FPS is just too much for even the new AppleTV to handle.
You’ll have to convert this into a more manageable 30 FPS file using Handbrake.
