I have did some testing with 3 APTV2 and recognised the following Problem. When Jailbreaking with Seas0nPass 0.78 for the FW 4.3 I have really Problems with the use of the SlideShow within the iPhone-Settings. Randomly it crashed the APTV2 when navigate through the SlideShow-Settings and reboots. I was able to simulate this with 3 different APTV2 with this firmware. Also this Firmware wasn’t able to find the ntp server while its boots for the first time
Then I downgrade all these 3 APTV2 with an Jailbreaked Firmware of 4.2.2 and then the problem doesn’t accured. A friend of my the the testing of the Original FW 4.3 and he has no Problem with the reboots while navigate the SlideShow-Settings
I have noticed the same issues while in the slideshow setting on the actual apple tv. Same setup and versions for me also. It seems to stop sending signal to the tv but if i press menu to back up a step it will still make the sound. Although its very glitchy and may not make a sound every time.
Same thing is also happening when I turn on last.fm then go into the slideshow. Signal to TV stops while ‘some’ audio works. Song stops but menu sounds seem to semi-work.
I am experiencing the same problem with 2 APTV2 and Aperture library. I connect to my MAC and navigate to the Photos Menu. There I can see the different projects that can be chosen. When I set the slide show settings, sometimes the APTV will freeze and I will have to reboot it. When I run a slideshow it does it smoothly until I press Menu (or pause) when it will always freeze having to reboot again
I use this feature of ATV2 a lot (specially after summer holidays when I torture friends and relatives with this year picture) so I will appreciate any help
Is there any news on this topic? I have the same problem…losing signal when going to slideshow settings or playing a slideshow. Is it possible to downgrade to 4.2.2 to solve the problem?
Thanks, that´s great to hear. I assume i find this setting in your atv-flash menu. I have not yet installed that, i just used season pass…but i will do so now. Thanks a lot.
