Maybe someone else had already the same situation: I want to use my iPad 32GB for Long Distance Travel to watch Movies offline via Infuse.
But 32GB is not that much. I saw that it should be possible to store moives on an memory extension, but I havent found any which is supporting also charging of an iPad while using the memory extension.
Any Tips?
Br,
Johannes
If you have a usb-c buy the hdmi out dongle that also includes a usb-c and usb-a port.
unfortunatley not.
Its a normal iPad 10 (2021) with Lightning.
There might be some sort of weird dongle or dock out there but if not then you’re either charging or using storage.
james
May 25, 2021, 1:53pm
5
This isn’t a combo we’ve tested, but you could try this Belkin adapter coupled with a SanDisk iXpand Drive.
Designed to be the perfect companion for your iPhone, the iXpand Flash Drive offers an easy way to free up space on your iPhone, automatically backs up your camera roll, and even lets you watch popular-format videos straight from the drive4. The...
I checked on Amazon and unfortunatley only Headset supported…
I am thinking of a Wirless HDD as an alternative.
This might also work.
Lightning to USB 3 Camera Adapter
@JarvisMeier , many thanks. Got today the adapter and its really working!!!
system
Closed
June 30, 2021, 1:40pm
9
