I just wanted to ask if you guys are still having issues following the tvdb outage.
Most of my TV shows are now “gone” since yesterday, as in they do not appear on the lists at all. They have been merged with other shows.
For example, Game of Thrones is now inside The Walking Dead. Season 1 has all the episodes from both shows’ 1st season, etc.
Sure I love both shows, but never expected them to happily marry.
When TheTVDb started to come back online yesterday, it was returning incorrect info for a period of time. This could lead to issues like the ones you are seeing.
To resolve this, you can use the Edit option on the affected episodes and Infuse will be able to refresh the metadata and pull down the correct info. You should only need to do this for a single file in each series.
Thank you for the quick reply, and thanks for this great app. I’m glad I purchased PRO.
I tried to do what you suggested, yet it says it finds no matches. Tried it on several episodes of different shows too. Same result. It displays the filename of the episode I try to edit, then I input a query and get no results
You were right, this worked. BUT new issues arose. Have a look:
Blank folders with not so helpful names. For example, the folder 14GKW0~W is actually 13 Reasons Why when I open it, containing the episodes with the poster, synopsis, all details, etc. i tried refreshing the metadata but nothing works.
The second blank folder is The 100. When I open it, I only see the episode filenames. No posters, no synopsis, no details.
Many shows have the wrong posters, even when the rest of the metadata are correct.
Other shows have posters in the wrong language. (Yes my ATV is in english, and the language options in Infuse, too.)
Per-season covers have vanished. For example, The Big Bang Theory had a specific cover for each season. Now one for everything.
I am definitely NOT blaming you, I am just reporting the issues caused by theTVDb.
On a sidenote: Can we please have an option to search for other covers/posters for the main folder AND the subfolders/seasons? Other apps search in sites such as theposterdb, fanart.tv, cinematerial, etc.
We’re getting a few lingering reports of issues with missing artwork in some case. It seems this is related to some of TheTVDb’s CDN caches which may still need to update.
I’d give it a few hours (or maybe a day) and try refreshing the affected series, and hopefully everything will appear normally.
How does one refresh a series? Do you just re-select its match when choosing to edit metadata? I have a bunch of Russian-language posters for English shows.
The current state is that finally the English language is respected for the posters.
BUT we still have the generic poster for all seasons.
This is hard to be seen as a CDN/cashing issue, as the posters for the seasons are separate altogether. Probably this issue needs to be looked at?
It’s ok for a series with 1-2 seasons, but for 25+ the separate posters are a big deal
