steam from same source at home and away from home
I hope to access to my NAS both at home and away from home.
So I setup a NFS protocol to access at home and a webdev protocol to access away from home.
Than I got duplicate file in my library, so what should I do.
Infuse currnetly doesn’t have a great way to handle using different connections for the same device, but you can make a few adjustments to allow things to be more usable in the current version.
  1. Decide which connection you plan to use more, and ensure that share is selected in the Settings > Library menu.
  2. For the other share, uncheck the relevant favorites
  3. When you want to access the unchecked share, simply access this via the Files tab instead of using the Library.
