Hi all,
i managed to “hack” my ATV with ATV Flash. Everything worked fine… i now realized that i miss the start sequence…the one at the beginning. How can i get that back?
Hi all,
The start up movie will disappear if you manually updated the XBMC/Boxee launcher through the update menu. If you ‘downgrade’ to the 0.8 version through the same menu, the start up movie will return.
I’m facing the same issue. How do I downgrade Boxee?
