SSH PROBLEM
after installing atv flash, have installed Cyberduck in order to establish SSH connection, but its allways the same: connection refused.
when opening connection on Mac’s terminal its says password deny,
any possibility to “reset” the whole connection thing and start over,
by he way, tried to connect also with PC, but the same results,
thanks in advance for your kind help,
Sure. You can toggle SSH and FTP on/off through the nitoTV  Settings > Utilties > Services menu.
thanks Max, now everything is just OK
Could not connect to NAS, it said afp not installed, after reading your forum, try to follow the command, but
Am unable to enable/disable SSH, AFP & FTP, why ?
Is it corrupted ?  Need to reinstall aTVFlash ?
