SSH not present
Dear all,
I' d like to SSH in my Apple TV box (1st Gen), but can't.
When I try to enable SSH via Nito, it does not work and I'm getting the following error in the Console logs:
NitoHelper[1038] Can't enable SSH server: sshd binary not present
Finder[553] ssh toggle finished with status:0
Any idea how to get sshd at the right place?
I can FTP but do not own a Mac, so can't copy any compatible file.
I'm using the last version of ATV Flash and did an upgrade of last Apple TV firmware through it.
Thanks in advance,
Jean-Frederic
Any idea?
SSH will be enabled by default after installing aTV Flash using a USB drive. If you're having trouble you may try reinstalling using a USB drive.
