Spinning Circle every few seconds
Since the last update 5.7, I just keep getting the spinning circle when trying to watch a program on Infuse. I’ve tried rebooting the ATV4K and closing the app but just the spinning circle afterwards? Any thoughts?
What type of device are you streaming from? If using SMB, you may try one of the tips found here.
You may also try updating to 5.7.1 to see if that makes any difference for you.
Thanks, I’m streaming from a windows 10 PC. It is working now and I think I may know what was causing the issue last night? I was copying gigabytes of data from one drive to another drive on this same machine when I was trying to watch content. Could this copying have cause Infuse to not streaming consistently since the machine was busy with this copying?
Uhhh yeah
Windows 10 PC is the problem. I was doing that at first, and once I switched to FreeNAS (I have since changed to unraid), the problem went away. It’s Windows.
Hmm? Never heard of FreeNAS or Unraid?
As mentioned above, this was most likely the result of the other activity happening on your PC while attempting to play a video.
If things work normally while you’re not copying massive amounts of data, then there should be nothing to worry about.
Yes, I’m leaving things as is since it’s back to working when not copying massive amounts of data.
