Speed test Crash-bug
Infuse crashes when clicking on the video percentage while testing SMB speed on Win11 over a local area network
You may want to run the diagnostics right after it occurs and post the 5 digit code here.
We’re looking into this issue. Thanks!
100%trigger
I was referring to this
Did you receive it? I sent the data wrong using another email. code:Q8Z1E
Please let me know if there is anything I need to provide or do, and I will give it a try. Thank you.
Thanks for your report.
This will be fixed in the 8.3.8 update which is being submitted to Apple this week.
A fix for this issue is available in Infuse 8.3.8 which is now available. :slight_smile:
