Specifying Fanedits
How do I edit a fanedit on Infuse to mark it as a separate movie and give it a new title, description and background?
I believe you’ll find the info you’re looking for in this user guide.
That’s great thanks. Do you know how I could download the XML and images from TMDB so I don’t have to manually download and recreate the entire file?
There’s not a way to DL the XML file but you can usually copy the graphics from TMDB. You can DL the XML file from the users guide at the bottom of that page and modify it as you wish.
Bigger question, if you want the graphics and metadata from TMDB why would you not just have Infuse fetch it instead of trying to reproduce it?
Infuse can’t fetch it since TMDB doesn’t have fanedits. What I want to do in most cases is change everything but the cast. Entering the cast manually is rather tedious and the actor pictures don’t load. I thought maybe downloading the entire info from TMDB would also give me the cast pictures along with it.
To be honest, I wish there was a way to have an XML file that replaces only certain values and fallbacks the rest to TMDB.
I apologize, I wasn’t familiar with the term “fanedits”. I misunderstood thinking it was another term for the user entered metadata on TMDB.
After Googling it I think your stuck doing it manually for custom metadata, sorry.
Thanks anyway for the help!
