Don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion! ![]()
Hello,
I have a Synology NAS, an Apple TV and many IOS device.
I set up local NAS access and Webdav for remote.
When I’m at home, no problem, I can play video directly from the library.
But when I’m on remote (specially on IOS), I need to browse in file because I can’t play movie directly from library… I have an error if I click directly on the tile of the movie from the home page.
Is there a tips so Infuse know if it needs to reach media through Local or Webdav. If movie is not available from local access, it uses webdav access.
It’s not very annoying but kids are lost.
I’m also using Jellyfin behind Tailscale, that would be cool to have both, see the home assistant app implementation, internal and external access
please add this feature!
Hmm Have you tried adding your server twice? Once with the (LAN) hostname and another Jellyfin entry using the internet proxy hostname (from Cloudflare)? That way you can manually select which network path will be used.
HTH
Hi guys,
I have a number of devices which I take out of my local network on a regular basis and these connect to my Jellyfin library via the external server address I’ve got set up for it. My other devices which are always on the local network connect via my NAS’ IP address.
For the sake of speed, it would be nice to have the devices that move be able to connect via IP when on the local network and when outside the network and the Jellyfin server can’t be found using the local network IP address have it fall back to the external server address.
Does this sound plausible?
I moved your post to an already running request for this feature.
This has been added in today’s 8.4.8 update. ![]()
How does it work on macOS ? Thanks !
C’est forcement du WebDAV ou ça peut-être une seconde IP (VPN)?
Mod Edit For Translation:
Is it necessarily WebDAV or maybe a second IP (VPN)?
I’m sorry if this is a silly question, no, that’s sarcasm, but is there a link where this is explained? When I searched, I only found a version for tvOS. Merci.
On macOS, click Files on the left tab bar, click Add Files on the top right, click the pencil icon of your current share/server, and click Edit Endpoints. Make sure to update Infuse via App Store first.
You can enable or disable endpoints by clicking on them. Infuse will attempt to connect to any enabled endpoints, and if that connection fails it would then try the next enabled endpoint.
If you are away from home, it most likely will skip over the primary endpoint even if it’s enabled and attempt to connect to the secondary endpoint. However, this behavior can vary depending on the network and the type of response Infuse receives when attempting to connect to an unavailable endpoint.
Also, on Mac, you can go straight to the Edit Endpoint screen by right-clicking on the saved share in the Files menu. Other platforms use a long-press.
Can I switch my primary and secondary? I currently have WebDAV set as primary, but it seems that if I want to use local as primary, I have to delete and start from scratch?
The primary address cannot be changed, but you can add a secondary address and disable the primary which would have the same effect.
If you truly wanted to switch them you can remove the existing share and add a new one with your preferred primary address.
Hi all I’m still having issues getting this to work. I’ve set local as my primary endpoint which works fine but for WebDAV I have no option to set the port? And that’s not working. The URL that I entered is correct.
Hello, any news?
