Sound from wired headphones possible?
Would it degrade my sound quality at all using wired headphones on a Apple TV streaming device?
Got it. Thanks.
Using wired headphones shouldn’t degrade the audio quality at all, but of course the quality of headphones can vary quite a bit.
For example, if you’re using the headphones from a 1989 Walkman it may not be quite as good as a pair of wireless AirPods. :wink:
That said, to use wired headphones with the Apple TV you will probably need to plug these into the TV or AV receiver, and it’s possible those devices may introduce audio effects which could have an impact on how things sound.
