Sort options
I am wondering if I may be missing something. I used to have the ability to go into my library, the overall folder, and sort by name, date added, etc. I believe, since the direct play update, I have not been able to do this. Will this be added back in? Is there another way to do this?
If you’re using the new direct mode then it’s coming soon.
Check out what planned for 7.7.5
Oh okay! Perfect. Awesome, thanks!
