Sort Library
Hi!
Is it posible, to sort the Library by filename? I hate, that for example “The Hobbit” is sorted as “The Hobbit”. The files Name ist “Hobbit, The”, so it is sorted as “Hobbit”.
Thanks a lot,
Robert
You could use a XML-File belong to the Movie-File,
With this XML you can set another “Title” wich appear in Infuse, but the file could named how you like :slight_smile:
Thanks a lot!
