4. Connected to WiFi, Home Sharing working, AirPlay enabled, get error in subject
5. Read forums, say to install XBMC, says installing, restarts LowTide and no XBMC menu
6. I have updated nitoTV, Rebooted AppleTV, Restarted LowTide, updated All, and several combinations thereof and still get the error trying to install aTV2 Flash!
FWIW, I can get Weather, RSS Feeds without problems. It seems like nitoTV and aTV Flash just cannot install software on my box!
No dice! I have the menu but nothing installs ... same thing that happens with nitoTV, etc. It appears to install, restarts LowTide then nothing there even after a reboot. I guess I'll be installing all the apps manually from the command line. What a disappointing way to spend $20 ...
Same for me, did same procedure RC 6 (not as this time with rc 6.1) for about a week ago worked like a charm .. could it be rc 6.1 that messes things up... think i still have rc 6 on harddrive must try ...
jailbroke with seas0npass. installed plex, xbmc, nito, all via command line. everything works (except i cant get xbmc to find a server, and plex has errors for all my files but at least finds the server, but thats another story)
bought atv flash black, hangs on transferring files for a while then gives the error maintenance error 8.100. bit dissapointed i spent $20 and it won't even install :( any ideas of a fix for this? i was hoping the plex client installed through atv flash would work properly.
I've also installed maintenance from the command line and cannot get any packages to install is there some other way to install couch surfer via command line?. (that installer was awful.... I tried it on different PC's multiple OS's same exact error I wish while it was transfering files it would also show total progress so atleast I have an idea of what is going on.)
I have the same issue, and also used GP RC6 to jailbreak. I bought aTV Flash when it first went beta and have been skeptical of trying it because I've been seeing complaints in forums. I finally tried it because I felt that with a beta 3 that a lot of the issues should be worked out. I was wrong, and very disappointed. I'm a software engineer myself, so I do understand bugs do happen. I think the firecore team should pay attention the number of complaints and consider a little higher quality and more testing around it's public betas, otherwise don't make it publicly available. The good news is that this particular issue doesn't stop me from using my aTV how I have been, however, I'm starting to question the quality of the software firecore is releasing.
Maintenance app wasn't too useful for me yet, so removed it.
Plex has some interesting plugins but seems to be more useful for beyond the USA content. Installing the Plex Media Server also seemed to interfere with iTunes serving of content to AppleTV2 and couldn't live without that.. so removed and purged the Plex Media Server and then the Plex app on the ATV2.
Overflow - (major issue) if you take the [Computers] off the main menu, [Movies] and [TV Shows] loose their Coverflow Art.. really didn't like that, but put it back and they come back.. kinda panicked me because it was such a drastic change. (may be seeing more flakiness with the CoverArt but not sure yet).
My opinion is the XBMC app with the bluecop plugins make a huge difference in the content choices available.
Hmm ... when I launch the atvflash (beta3) installer it sees my ATV's but it just hangs. Nothing gets transferred and I have to force quit the installer. I have manually installed Plex and Overflow. I removed nitoTV. Perhaps that is the issue?
philip
Edit: Hmm ... it seems to need a nitotv library. I installed that and it installed.
