The seven deadly sins (…/the-seven-deadly-sins – I can´t post more than two links).
Searching the metadata in the app suggests movies, but not the correct anime metadata. The metadata is one of the main reasons to use Infose (the another one is the formats compatibility).
I know the file naming in anime is tricky, because of the episodes not classified in seasons.
But i’m not talking about the auto fetching metadata, I didn’t get the right results searching by title neither of that shows (I get some movies, but not the main show).
When Infuse searches for metadata it looks at the file name to see if it has a season/episode in the file name, in which case it looks for a TV series; otherwise it assumes it is a movie.
So having something like S01E01 in the name make Infuse look for a TV series.
I suspect that your file names didn’t include season/episode form recognised by Infuse.
There are forms other the S01E01 recognised by Infuse (such as 1x01) but this is certainly the form I personally have standardised on.
Yes it does as @remotevisitor said above.
If you don’t have the “S0xE0x” in the file name Infuse will look for movies. If it’s there then it searches the TV show database.
