[solved] Does not jailbreak
I am trying to jailbreak my apple tv 2.
It is able to go through all the steps in SeasonPass without any errors. But, when I plug in my apple tv to the power and hdmi, it seems that it’s still locked. I don’t get the season pass logo or any of the option to install media player.
I am currently trying to jailbreak from a macbook pro running lion.
Can somebody please help me.
There is no immedaite visible sign that you have succeeded in the Jailbreak. There are two ways that you could check:[list][]See if the ATV Flash (Black) setup program works (which then installs the FireCore Maintenance Menu option) [] See if you cna make a ssh connection to the ATV2  [/list] Either of these working would indicate a successful Jailbreak.
I feel so dumb now.
So yes, jailbreak has been workig all this time, confirmed by ssh-ing in to the apple tv. I just hadn’t installed FC aTV on to it
Thank you for your help! :slight_smile:
I think a lot of people get caught out by this.  One of the earlier releases of SeasonPass used to temporarily add a SeasonPass menu item (selecting it simply removed it) to give a visible inidcation of the Jailbreak.  I think that FireCore should put this back in the next iteration of SeasonPass (probably for iOS5 Jailbreak).
I think he should leave it the way it is. I got caught in it because I thought that it would add the menu option again, like before, but as people get used to it, I think people will get used to it. And maybe someone will write a guide that mentions it at some point (or updates the “wiki”?)
