Smb with out saving
hi quite new and a little unsure, what I’m also wondering is if you can map up an smb share and watch without scanning it in. but just map up, browse and watch the content and then remove the mapping. I have plex and jellyfin and it works but sometimes you want to watch it from your mobile and what I want to be able to watch are courses and there you get them in course, episode, section therefore browsing option but it gets mushy if you get it scanned in.
You would need to save the SMB share in Infuse before being able to access it, but you can limit or avoid content from that SMB share from being scanning into Infuse’s library.
There are 2 things you can look at.
  1. Add a favorite for a folder on that share, and deselect that favorite in the Infuse > Settings > Library menu. This will prevent Infuse from displaying these items in the Library.
  2. Set that favorite to use local metadata. This will prevent Infuse from trying to match items in this folder to titles on TMDB.
