SMB username greyed out
I get access denied when trying to connect to my SMB share. I can change the password but not the username, so it has the default username. How do I change this so I can set the correct username for the SMB share?
Thanks.
You’ll need to recreate a new SMB share I believe.
Thanks. I think you’re right, but I resolved it as I had changed my host name so I changed it back and it worked.
