I’m experiencing stuttering/buffering issues across multiple devices, not isolated to one home either.
I have two homes, one of them has:
Apple TV 4K - 3rd Generation (2022)
The other has:
Apple TV 4K - 2nd Generation (2021)
Each are connected to Synology NASs and had been working fine until updating Infuse. The 3rd gen is running tvOS 27 while the 2nd gen was running tvOS 26 (now 27) and also had the same issue.
I wasn’t certain that it was Infuse but just played a movie watching Plex and it ran fine (all maxed out options using direct play).
Things I’ve tried:
I just tested on my MacBookPro (M5 Max) and confirmed the same stuttering behavior
I was using Automatic for SMB options but switched it to Legacy to see if it would help and no luck
I uninstalled and reinstalled
I’ve rebooted
I rebuilt cache
I tested the network (25Mbps avg, with no drops)
Update:
When I tested using Plex, it was the standalone app. I just tested using Plex via Infuse and it’s playing fine. Looking at the Plex dashboard I can confirm it’s playing using Direct Play and am seeing average of 130Mbps. I feel fairly confident saying something is broken with SMB.
Based on your testing, I think this is most likely an SMB issue in Infuse rather than a network or hardware problem. Given it’s happening across two homes, different Apple TVs, different Synology NASs, and even on a Mac, it looks like a regression or compatibility issue with Infuse’s SMB handling.
This could be part of the problem. When you do a speed test it’s usually best to let it run to completion and then make sure to look closely at the graph. It will often show dips that may give you some indication of what’s going on.
Also something that I noticed after getting brave and updating to OS 27 and the 8.5.6 Infuse is Infuse did a rescan for a chunk of my library on all updated devices. I don’t know why but it did take about 30 minutes to an hour to complete. During that period it was sluggish so maybe that’s what you’re seeing. Check the Library settings page and see if it’s still scanning/updating your library.
It sounds like you may be streaming remotely from the Synology, is that right? SMB can have some limitations when streaming over the internet and some ISPs may even block the ports it relies on. In general, WebDAV is better suited for remote streaming since it uses HTTP/HTTPS and typically has less overhead.
Also, if you can run a speed test in Infuse, this may help identify where the bottleneck is occurring.
If you have the ‘Streaming Cache’ option in Infuse > Settings > Playback set to ‘Auto’ Infuse will continue to cache a larger portion of the video based on your available disk space. This can range from a few seconds to many minutes of video, depending on the video size and free space available on your device.
Also, pausing the video for a few moments while it is playing can allow Infuse to build up its cache which may help avoid buffering on slower connections.
