Smart Installer Error
When I try to run the Smart Installer it always ends with “an error occurred”.
How do I get past this?
bob
ATV 3.0.1
aTVFlash 4.0.1 (just bought it and d/led today)
Is the nitoTV plugin currently installed? This plugin is required for the Smart Installer to complete successfully.
This item can be installed through the Maintenance > Manage Plugins menu.
I assume it was. The first thing I did after the reboot of the thumb drive was run the smart installer in maintenance.
It’s working now, but not until after I rebooted and went back to a factory restore.
It’s all working fine now.
Thanks for your help.
bob
the downloading of the 10.4.9 Combo is very slow and can result in this error (currently downloading takes about 8 hours), thanks to Apple most likely
Cheers
Dannie
Same Problem
How can help…
Jan
Can you check the version of aTV Flash you have installed?
Maintenance > About
I am getting a similar error on Smart Updater. I am using 4.0.2 and I get an error saying that there is an invalid character h at line 1
