It this just me or do you guys also see some improvements on this point with tvos 10.1.1 ?
It’s not completly ok, but it’s a little bit faster.
Opening favourites and playing files is so much faster with 5.2 for me. Back to speeds I remember from v4
Since I installed 5.2 update… I can’t access to my Synology NAS using SMB as always… every update solves something and breaks others… any solution?
EDIT: Finally solved the problem. The last Synology update disabled the SMB on the NAS.
I got Qnap at home and it used to take 10-15 sec of loading before the 10GB movie started.
I changed Share setting from Auto to SMB3 and worked.
Setting → Share → advanced
