Slow transition between episodes
Hi @james
I’m referring to the following post:
New NAS (UGREEN) – now it always takes a few seconds until the next video starts
Unfortunately, the issue still persists even after switching to SMB2.
Interestingly, I only experience the issue on my 3rd-generation Apple TV 4K. It does not occur on my other Apple TV 4K, which is a 1st-generation model.
Both Apple TVs and the UGREEN NAS are connected via 1 Gbit Ethernet. I also did not experience this issue with my previous Synology NAS.
Yesterday, shortly after the issue occurred again, I generated the following diagnostic code:
RX501
Could you please take a look and let me know if you can see anything that might be causing the issue?
Thanks!
Have you tried changing the Streaming Cache setting? Maybe try Limited or legacy.
Doesn’t make a difference. I have a feeling that it might be related to the “Skip Credits” feature, which I have turned on. I turned it off and now I have to further investigate.
