Slow seek on AppleTV
After doing a seek, it takes about 5 seconds or more to play the video, I’ve already changed the “streaming cache” to memory only and legacy but it hasn’t changed absolutely anything, I’m using plex as a backend but I’ve already tested with jellyfin, emby and smb as a backend and they all have the same performance, on other players (plex, jellyfin, etc.) it is much faster, any idea to solve this?
Thanks.
Infuse Pro 7.6.5 (4656)
Connected via WIFI (eero Pro 6)
Speed test in Infuse with Plex as backend for this movie:
File Size: 35.76GB
Average Speed: 809.12 Mbps
Current Speed: 833.62 Mbps
Minimum Speed: 711.98 Mbps
MediaInfo:
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 3 h 26 min
Bit rate                                 : 24.1 Mb/s
Width                                    : 3 840 pixels
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.39:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Original frame rate                      : 23.976 (23976/1000) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.163
Stream size                              : 34.6 GiB (97%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1342 cd/m2
Maximum Frame-Average Light Level        : 144 cd/m2
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 1.11 GiB (3%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
It may help to specify what version number of Infuse, WiFi or Ethernet, speed test results in Infuse and specs on the video you’re seeing this in.
Does the file have Dolby Digital Plus Atmos? I find that videos with Atmos have a delay when seeking. Non-Atmos files are instant for me.
Sure, I edited the topic adding more information.
Yes, I noticed the same, files Non-Atmos are faster to seek, did you find any solution?
EDIT: on the iPhone it works perfectly, fast seeks
