Atmos requires more bandwidth to play. Low bandwidth like you have can cause this issue.
I went through FTP. and Iām now at 300 Mbps. Dolby Atmos is no longer a problem. Thanks for helping me
What do you think is the best protocol between FTP,SMB,NFS and WebDAV?
The one that works for you.
Thatās the reason there are options, not everyoneās setup is the same. Sounds like FTP is working for you. Iād suggestion not tempting fate since it works now. LOL
yes it works on reading but I lost performance for synchronizing the contents of the library (4000 files on the NAS)
Do you have embedded metadata turned on?
No si turned off
Good, leave it off. Let Infuse gather all the meta data now that you have changed the protocol and it should be fine after it finishes the first time.
Nice thx
I think itās simply because my folder with my TV shows has a lot of subfolders and FTP doesnāt like it too much.
