Skip Credits just doesn’t work
As title, skip credits doesn’t work fully. Seems to be primarily on Netflix shows but i dont see why it would be different.
Skip credits does skip to the end…but then everything gets stuck. Next episode does not start. It is not clear if infuse is playing or paused. When trying to get it to play infuse does absolutely nothing.
Only solution is to exit out, manually mark the episode as played. Then play the next episode.
What is the point of this feature? Please change it to a “Play next episode” button instead. That would be much more functional.
Are you using Plex, Jellyfin, or Emby? If so, what version?
Plex indexes. Infuse plays on Apple TV app.
Plex server 1.41.1.9057 latest infuse app. Up to date Apple TV.
This has been causing issues for a long time but i have gotten fed up so am mentioning it now.
Usin Plex in library mode as i found direct mode unusable.
Do you have Plex Pass?
Yes i do. Lifetime
Exact same settings and works fine for me via direct mode. Maybe device related?
