Hi Firecore,
I have recently discovered the wonders of Sickbeard (and ahem associated programs) and am wondering if it is at all possible to for Media Player to use the ‘metadata’ folder that SB creates upon downloading and processing episodes?
Many Thanks,
-timeimp
Did you ever find the answer to this?
SB works fine with infuse, just point infuse share to where SB looks for your shows, in that folder unless you are deleting them are your .nfo files, and with the exception of the occasional show, Hawaii Five-0 etc, that need to be renamed infuse will snatch the data and use it…
at least thats my experience ymmv
