As stated after the update today, a long Play press hovering over a TV series cover no longer brings up the options (mainly shuffle). This does happen on the main TV folder or Movies and Playlists still however
Yes, it’s a bit strange. Shuffle seems to work within seasons only, which I assume isn’t exactly how this feature is intended to work. It should work for seasons and also the series.
Glad to see it in the upcoming features list as a fix!
Confirming seeing the same: Holding play/pause for shuffle is now available only on the home screen. It was previously available with TV Shows.
Is this possible to fix?
I moved your post to a thread discussing this issue. Note it’s tagged as in progress.
This has been resolved in today’s 8.1.1 update.
Thanks for your patience.
When holding play on a TV Show there is still no shuffle option. The shuffle option seems to only be available when selecting an episode on the home page, and there limited to that season only.
I would say this is not fixed.
Update: When switching back to library mode, the shuffle option is back.
