[Showcase] Favorite icon artwork
Try a computer, its a .zip file :wink:
Thanks, they are really nice.
Do you take requests?
Well These are pretty cool. BUT porn should be pink;).
wouldmlove to have tv serier og samlinger/bokssæt
Yeps! -Just name it :wink:
I will make them :slight_smile: -And thanks!
Awesome ?
I could use these:
  • TV-serier
  • Film
  • Nyligt tilføjede film
  • Usete film
  • Bibliotek
De er her, desværre har jeg måtte ændre i de lange navne da der ikke var plads.
Altså de er jo piv flotte. Hvis du er i mode, så ville jeg sætte stor pris på:
Disney
Tegnefilm 4K
Jul
Boxsæt
They are awesome :slight_smile:
Thanks a lot :wink:
Der er desværre en begrænsning på antal bogstaver, så derfor kun boxsæt og tv-serier, håber det kan bruges.
TAK! -Jeg lukker ned for i aften, ser på det i morgen :slight_smile:
I can’t add favorite tile images! What do I do wrong?
I have set tree different favorites; “All movies” (my entire library), “Playlists” and “Collection” with my collections.
The “All movies” is actually a folder but the “Playlists” and “Collection”-favorite is not.
Therefore I taught the option 2 was straightforward; I uploaded the artwork in the original “All movies”-folder (where all my videos are) and when I long-press on one of my tree favorites and clicks “Select Artwork” option to browse for an image I can’t find it anywhere. All the movies are there but no images..
What do I do? :frowning:
I just did these. I did use the actual icons I found on some free to use site and change them a bit.
They look awesome! Could you please make them in English as well? For TV series for example.
And maybe some other color options? Like neon pink would look perfect next to the neon blue.
Hello,
I have a favorite folder that I already have icon that I put. Then I find this amazing thread and I want to change. But I can’t…I already clean the image and put the new one, the icon appears there but when I go to main page always get to previous one. I only can put the original Star, when I had a new icon always the first one!!
Any help…
maybe you can try to put the picture outside the folder but name it exactly like the folder
double post
Ok, it works. Thanks for that.
One Serie i have its Black Mirror but it find the serie but dont have many information. I see i cant add information in a file and put inside the folder right? And type of file it has to be and what name i have to put in the file.
And the same with poster of season for exemple…i have to put the image of season poster insede each folder of the season or i can put in the folder of show but outside of folder season just rename it!!!
Is possible to edit the name of Serie? Because it appears with english name but i want with portuguese, but just a specific one?
It is possible to create a xml file like in movies?
Im sorry by my english i hope you understand!!!
Many Thanks
My Google Drive version
Enjoy!
Hello
James if you see my post
is thre a way to get the infuse logo in a good quality
want to make one for a category to my infuse
thanx
