Show chapter name
I’d love it if Infuse showed the chapter title when you switch chapters on the playback bar. Would it be possible to indicate what chapter is playing in the iOS control center too?
I have just started to use infuse, primarily with mkv files from concert and music sources. It would be really nice if I could rename the chapter names to the actual songs. Is there a way to do this, perhaps by adding some xml to the directory?
You might be able to edit the chapter names using mkvtoolnix.
