I am trying to find out if it is possible to share movies that I have synced to my iPad with other devices on the same network. We are going to be in a car with a travel router. I was looking into getting a hard drive to attach to that, but I never got around to getting one. Can Infuse do this?
No it won’t. You can download the movies in infuse and then use Files on that device to airdrop them to the other device. The other device can then open those movies up in infuse through the files app.
You can also share files via AirDrop directly from Infuse.
- Open the video details
- Tap 3 dots menu
- Select Share
- Tap the AirDrop option
