Hello and thanks for reading this.
I’ve been using Infuse for the past several weeks and it’s a great piece of software, so far.
I’ve been trying to use the SFTP connection to connect to a precise directory on my shared seedbox.
Let’s say the directory I want to go is /home33/my-username/this-specific-directory
. The software’s first location I’m sent to is: /
. In there, I can see many different home directories: /home1
, /home2
, …, /home33
, /home34
etc
However I’m not authorized to display the content of these directories, meaning that I cannot access /home33/my-username
, Infuse says an error happened as soon as I double-click on /home33
Could you help me resume that setting? Maybe there is a way to straight up write the proper path in some textual parameters instead of the most rigid file explorer of Infuse?
Setup:
Infuse Version: 7.3.4085 (r535ad2f7867c4f22b655a0585f33caf3e503d17c)
macOS 12.3.1
