Brand new ATV 4k. Brand new install of Infuse Pro (trial edition right now).
I really want to use Infuse over Plex. Currently the Infuse client is connected to my Plex server on a Synology NAS. I’m getting incredibly annoying color banding using Infuse that does NOT happen when I use the Plex client. I can’t figure out why. The ATV is set to DV “dark” mode on my TV, and no smoothing or color enhancements are set. (TCL 65" 6 series).
Forgive my ignorance but if my TV supports HDR (HDR10 and DV) , why would I want to select SDR?
EDIT: found this elsewhere on the web so I think you’re correct “ Because not all apps flag for SDR content which means that SDR content with have a “fake” HDR grading applied to it (DTVN is an example). 4K SDR with Match Dynamic Range and Framerate set to in ensures that SDR is SDR and HDR is HDR (regardless of flavor of HDR).”
Went and changed the settings, didn’t fix it. Still severe banding. Using 4K SDR, match range and frame rate, and left the chroma and HDMI format to their defaults.
This looks like kind of a strange file, as it has a 10-bit depth but an SDR color palette (bt.709). A file with bt.709 colors will typically be 8-bit.
With dynamic range matching enabled, Infuse should be switching the Apple TV to SDR mode for this video. Is this what you are seeing, or is it going into HDR mode?
Does forcing the Apple TV to SDR with dynamic range matching disabled change how the video plays?
Hey James, it was switching it to HDR but I took the above users advice and set my ATV to 4K SDR with match range. It is now not flagging it as HDR but I still have the same issue and what appears to be identical image quality and banding.
I haven’t done an audit for all the video files so I’m not sure how many are tagged like this. I did however just finish uploading a 15 second clip that includes the portion in question. I’ve removed audio to make it smaller in size.
Hey James thanks for looking into it. Is there a way to follow the issue and/or get notified of updates? I’m running the trial of Infuse Pro right now but am just waiting on this one issue to buy a lifetime and kick Plex to the curb!
Sorry for my bad English.
Now I am using apple tv 4K 2022 gen7 to playback SDR HEVC 10bit video,but the banding is still there.
If video were SDR 10bit HEVC,wether it is YUV420 or YUV444,wether it is 1080p or 4K,this issue can be reproduced.
Could you developers fix this bug?
I did some test and I found when I disable hardware accelerate in VLC or MRMC,the banding disappear.
I think maybe the color banding of SDR 10bit HEVC video cause of a bug of apple‘s video-toolbox.
