Hi
Just setting up library view and all of my files (approx 4050) are appearing in ‘other’ rather than ‘movies’ or ‘tv shows’. I am sure it is something simple that I am doing wrong. Any advice is much appreciated.
Hi
Can you check to ensure you have Metadata Fetching enabled? This will be required in order to use Library View.
