Setup for 4K
Hi everybody,
just bought a new TV (LG 55C7D) an upgraded my Apple TV to 4K as well :slight_smile: running infuse pro on it, of course.
Since i`v been reading, that it might be tricky to get the right setup for the best 4K&HDR picture with the TV an Apple TV. What are your suggestions ?
(i believe it is not a good idea if the ATv does the decoding and than the TV will do some decoding too ??)
Sub-question: why ist 24p so important ?
Christian
Hello,
Regarding 24p, you’ll find some information there : http://www.rtings.com/tv/tests/motion/24p
Regards
Bruno
