Settings info?
Is there some info about what all the settings do?
Like Dolby Effects for example?
You could try searching the forum for some of the others.
Dolby Effects attempts to virtualize the surround through stereo when using headphones.
It would be nice if there was a doc with an explanation about what each setting does.
Thanks for the Dolby effects!
