Setting a permanent playback speed for specific shows / movies
This is a feature I’ve been wishing for the longest time.
There are some shows and movies in my Library which I watch repeatedly and always watch at 1.25x and some others always at 1.5x. Every time I start playback of those shows after watching something else, I have to manually adjust the playback speed. While this is only a small snag, it would be a great qol feature to be able to set a speed for specific shows or movies.
Thanks.
+1 from me.
Alternatively, as someone who has Infuse set at 1.25x speed all the time…a change that would let you set a playback speed per favorite would make me happy. This means my Films and Music Video folders could be set to 1x…and I would leave the TV Shows folder at 1.25x
Hi guys,
while watching a video you can manually set the playback speed.
I watch old Animes like Dragon Ball or Pokemon at 1,25 speed. However I always have to manually change this.
It would be cool if you can set this setting for a whole show or a season so you don’t have always set this manually.
I watch some series with a specific playback speed.
It would be interesting if Infuse could save the playback speed for each TV Show or if there was a way for me to select the last playback speed more quickly. For example, choosing it directly from the video player without having to access the top menu.
[Sorry about my mockup]
I would also like to report a bug.
I like watching TV shows at some specific speed, like 1.4x or 1.6x. These options are not available. No problem.
So I need to use the increment and decrement buttons.
To make the process faster, I thought I’d select the 1.5x option and increment or decrement to the speed I want.
But suppose I select the 1.5x option and press to increment or decrement. In that case, the value is reset to the default 1.0x, and the decrement/increment happens using that value (1.0x) as a base, not the value I had previously selected (1.5x).
