There are many shows like that, and I there must be many people experiencing this issue?
This is the only thing holding me back from switching to Infuse.
Some examples:
Brooklyn Nine-Nine
The I-Land
Mayans M.C.
Border Control - Spain
Wu-Tang Clan Of Mics and Men
90 Day Fiancé - Before The 90 Days
The X-Files
Renaming everything manually works: the show is detected by Infuse, but that is not very feasible.
I have found no way to make Sonarr replace dots and dashes in episode file names automatically.
I am a developer myself, so I can imagine it is certainly doable to add support for this to Infuse? ?
I’ve had the odd Show not get picked up for metadata by Infuse - Catch-22 was the last one… just manually searched for and confirmed the required metadata in Infuse and it then recognized the other episodes without any input from me.
I use Sickchill as my PVR, it also uses thetvdb for metadata and once setup all works smoothly with show renamed as i specify.
Since characters like these are often used as spaces (Metadata 101 – Firecore), Infuse will sometimes have issues recognizing these characters when they are part of the actual series name.
We have a few ideas for how this can be improved, but no ETA just yet.
Ok, thanks for the info. ?
A braindead approach might be: if there is no metadata found: check for title that was tried the first time + the part after the next delimiter (space/dot/whatever), and so on. Easy peasy! ?
