I have a question concerning the visual of the series. I use a NAS and there’s a folder for each serie (all the files of all the seasons of a serie are in the same serie folder)
My problem is that when I navigate, some series have a folder logo with the name (when there’s more than 1 season) and some series have a cover of the serie (when there’s only 1 season). The « folder series » are first, and the « cover series » are after the folders … and they are not classified together in alphabetical order. I join a screenshot.
How can I unify those series in one (with covers it would be better) ?
Have you tried using the Library (via main home screen or search/browse tab) to access your shows? Generally, this will provide a much better browsing experience for TV shows as it will display artwork at all levels (series, season, and episode).
