Series is not recognized and not displayed under Series?
It’s about the series Reckless from 2014, which is not displayed under series but among others and there I only see the file names per episode. If I then edit the metadata of one of the files and search for Reckless, many things are displayed, but not the correct series. It’s about this series exactly:
Why are the episodes not displayed under Series but under Others?
Usually it’s how you have the files named and structured that causes this. How are your files named?
I just tried the following and it found the series with all the correct info.
Edit to add:
You can check names and years on TMDB
