Cubik
#1
Hi all,
Ik got i think a strange problem, i got the serie The Vampire Diaries and Revenge but it wil nog showup in the library
other series no problem but this 2 i can scan for metadata but it dussent help, does anyone know what I’m doing wrong ?
i checkt the name and its must be correct…
C.
kenny
#2
I think the question in hand is, what is the correct way to name the video files and or folders to make them show up for play listing as a TV series?
james
#3
You may need to change the content type for your TV Shows folder as described here: http://support.firecore.com/entries/20322512-Media-101-Basic-Setup
If that doesn’t solve it, you may try correcting metadata as described here: http://support.firecore.com/entries/20557283-Metadata-and-Cover-Art This guide also has a few suggestions on naming your TV shows to ensure they get picked up correctly on the ATV.
Cubik
#4
tnx for the fast answers, i put some screenshots with the message, becourse why must i change the folders of names ?
becourse i think metadate must find it ?.
and the other series also work (fine this way)
C
PS: pictures are take from my linux laptop for example folders on the nas
